Help Weird problem with power button
dockramer
This just started a yesterday. When my screen is unlocked, pushing the power button once does not lock the phone. A long push brings up the Phone Options menu. If the screen is locked, a short push brings up the unlock screen so I know the short push is working.
Bottom line, I can't get the screen to lock by short push of the power button.
Anyone else have this issue?
Ideas would be much appreciated.
Thanks
Thanks for the comments. Unfortunately, I had to wipe to device but it is now fixed. I believe it was related to an app called Tasker and a task which altered the keyguard settings.
Hello, just joined the forums here. Saw this thread and had to speak up...I was having this exact same problem and made a thread over at android central about it. I thought it might be tasker also, as I had a task to keep the screen awake while the keyboard was open. I deleted this task and the problem still persisted. I noticed this did start happening around the same time as I first tried the one click root. I got root fine but I noticed this weird issue a bit after. I can't say if it was that though as I had been messing around with the phone all night when I noticed the power button problem...I ended up wiping and all is good now. I am still rooted as the factory wipe didn't take root away so I am not sure what the problem was. There were a couple of people at AC that had the same problem and a wipe fixed for them. Luckily I had backups in place so it was relatively painless to get everything going again.
Sounds like Tasker is the problem w Keyguard tasks. I'll definitely be careful with changing keyguard settings in the future.
