Help Weird problem with Reppards CM7
Crex321
Aug 27, 2011
142
14
Does anyone have signal problems while using the new CM7 by Reppard? My Market only works with wifi. When I first flash it, the Market works, and I download the gapps I checked. But in a couple hours everything relies on wifi. When I have 1 or 2 bars, my Market, web, or any other app wont load. I've re-booted, and flashed it like 3 times, and get the same results, but signal improved while doing so.
It is a box that pops up when you use the market after flashing a rom. It asks, do you want to wait to connect to Wifi to use the market Yes or No ( its something like that ). i hit no, and my market works fine. Cause your whole phone works better when connected to Wifi so its no need to connect just the market only. That's just my opinion.
Upvote 0
BEST TECH IN 2023
Smartphones
