Optical Illusion
Reflection off the mirror you are pointing your phone at.
That "imaginary" red light that you claim is coming from the Proximity sensor is too low.
The Proximity sensor and the Charge/Notification LED are at the same level.
Looking at my phone at the same area, it is solid black so impossible for any light to be emitted from there.
Yes I am trying to trick all you people. Haha. Are you ******ed. Just because it hasn't happened to you doesn't mean it isn't real. I have better things to do during the day then sit around and make up hoax post. Thanks for your help. If someone knows what is going on I would appreciate the help. It may be lower than the proximity sensor but it looks like it is near it.
you cant see it with the naked eye, i am surprised you were able to photograph it.
you know how the eris can auto dim and automatically get brighter depending on the light situation? you know how it does that? a light sensor. thats what that thing is.
if you want to see it, go outside on a bright sunny day and look at your phone (almost parallel). you will see it.
I RETRACT WHAT I SAID
There is something there
I will post a pic shortly
Standby...
First, Redplate my apologies. You have to understand that to the naked eye it appears as if there is nothing in that area except a solid black area.
My curiosity got to me, especially after you seemed to be genuinely upset.
I took a macro photo with flash enabled and look what I see?!
Sorry bout that.
Not sure what it can be. Anyone??
Sorry I got so pissed. I just had a shitty day. That's it though. It doesn't glow super bright but it is a deep red. It only turned on when the screen was on. Now it is gone. There is either some kind of light in there or whatever it was it was red hot
