andyinmichigan
Member
So it just started today, when i'm in a text convo with anybody instead of the going back/forth, or mine being every other mine keep going down in order, but the incoming ones all list out underneath the same side. So if i get a message, i have to scroll up to see what they sent.
there are no settings to change this, i've checked. i also went to Manage Apps>All>Messaging>clear dta thinking maybe something weird got changed. No Luck, and then i had to restart so i could send text again.
if i can't figure it out i guess the next step will be backing up and doing a hard reset i guess.
anyone have any ideas?
