Help Weird thing with my LG-Esteem RAM
Today I noticed that the total RAM of my LG-Esteem reads 370 MB when it actually would read 512MB. The difference is 142MB. I shutdown the device and took off the battery and waited for a few minutes then inserted the battery back and turn on the phone again to see if that would help to fix this issue but to no avail. I know it read 512MB as total RAM when I bought it new last December but I don't know when this issue happened. I only know that by April I updated the phone from version 'ZVB' to version 'ZVD' sucessfully and it has been working without problems either before updating it or after it. My phone is not rooted yet. This anomally has puzzled me a lot. Has anyone in this forum has had this problem? Any ideas of what it is causing this issue?
Regards,
Carlos
This is normal. I believe the missing ram is being used by the Android OS. About 350-400 total ram is normal in our phones. And as far as I remember it was always this way, since ZVB
Are you sure mate? How much 'TOTAL' RAM does your LG Esteem read? I'm a little worried about this.
Regards.
Completely normal. Everyone's reads that amount. It only shows the ram available to the user. Just like if you go into the settings>storage it tells you you have half of what you really have for internal storage when in fact you have double. They other half is used by the phone/os
Yeah, I went to a MetroPCS store a few minutes ago and a friend of mine who works there showed me his LG Esteem and he said the same thing about the 'TOTAL RAM' thing. Now I'm relaxed it just freaked me out, that's all. I tend to compare these smart phones to the computers I use daily which use a different aproach in relation to RAM and storage. Well, end of story and thank you for your input. Nice forum here. :)
