Hi my name is eric i have a galaxy tab7" vzw. Just learning, i rooted with superoneclick. Joined because i'm having problems. Thanks for the help in advanced
You've certainly come to the right place if you need help with your Android devices!
I'm not familiar with tablets... you might get a quicker answer by posting in the all things root section of the sub forum for the device (I think this is the correct one for you - Samsung Galaxy Tab 7.0 Plus - Android Forums - not sure, as there are a couple of different galaxy tabs)
You should be able to post any issues you're having in there and get an answer from other isers of your device!
