D
Deleted User
Guest
Okay, standard warning nothing to worry about:
IF YOU BREAK YOUR PHONE, NOT MY FAULT OR THE FOURMS FAULT, FOLLOW ALL DIRECTIONS AND YOULL BE FINE. THIS IS ONLY FOR VIRGIN MOBILE USA OR SPRINT
Now that thats out there here we go:
A prl is the file that tells your phone what towers to use, and virgin mobile doesnt get to use all sprints towers, however you may use them if you were to connect to them. This is what increases your data, especially in a 4G town.
follow this exactly as I say!
You must download QPST, the prl file, an app on the phone and be rooted:
1) download this on the phone https://market.android.com/details?i...code.msl&hl=en
2) Open the app, and accept the superuser request.
3) Tap read MSL
4) Write down your MSL, youll need it
5) Go to the phone app, dial ##PORT# and hit on, then select.
6) Enter your MSL and click ok
7) Plug into a computer and download HTC diag drivers attached to this thread
8) Go ahead and google and download QPST
9) Download and unzip the attached 60681.zip
10) Now for fun, If anything confuses you, google it.
10B) go to the device manager, and select the unknown HTC device, then update driver. then browse>let me pick from a list>have disk>go to downloaded unzipped folder>choose the appropreate folder for your OS type>click the driver. Now open, next, yes, close. Right click HTC Modem, and go to Properties>Advanced port settings>see what your COM port is
10C)Open QPST CONFIGURATION and select port. then add port, here you type the port your HTC MODEM is on.
10D) Your phone will now show up, and you will click start client>service programing
11) click your device and ok.
12) DO EXACTLY AS I SAY NOW! NOTHING ELSE!!! NO LOOKING AROUND!!!!!!!
13) Click read from phone, Give it the MSL you wrote down
14) Now click save to file
15) Click roam
16) Click browse where it says file and in that you put the 60681.prl you downloaded AND unzipped
17) Write to phone. THIS WILL RESTART THE PHONE, BOOT MAY TAKE A WHILE DONT PANIC
18) Enjoy faster internet
3) Tap read MSL
15) Click roam
Working on the video now.
