Unicorn512
Like several folks I am getting the OTA notification for FRG83D (I have another post asking about changes to the build.prop file to suppress the notification) but I saw that Peter Alfonso has a rooted version available so I thought "What the heck, let's go for it!"
I have Rom Manger and ClockworkMod so this is the process I followed
1.) Downloaded the ROM (used WIN7) FRG83ODEXED.zip from Pete
2.) Put the file anywhere on your sdcard. (in SD root and Renamed it to UPDATE.zip)
Launched Rom Manger and selected Install ROM from SD card
scrolled to UPDATE.zip and selected
Checked POPUP BOX for "Backup Existing ROM" and "Wipe Data and Cache"
pressed OK
get POPUP box saying "Reboot and Install - Press OK to reboot into ClockwordMod Recovery and continue the installation"
pressed OK
DROID powers off then on - Displays "M" screen briefly then a screen with triangle with an exclamation point inside and a little rectangular DROID under it.
That's where I am stuck. No keys seem to work. There are no instructions to follow.
I can pull the battery and reboot back to where I started.
I looked fo ClockwordMod help, but have not found anything useful so far.
Can someone point me in the right direction please???
pressed OK
pressed OK
