What apps work on Ace2?
howieleem
I went on the Samsung website and i could not find the Ace 2 in the selection of phones when i tried to download an App. Anyone know why?
If i go to Ace 2 on UK website, there is a link to Apps, then if i choose an App such as Qr Barcode scanner, there is a pull down to check which phones it works on, and the Ace 2 is not in the list.
Poor website design. Even worse functionality for the Ace 2. Should have got an Iphone.
Only if you want to go to the bad, dark side......:D:D:D
Can't you just look on the Play Store? It tells you on the left if apps are compatible or not. Or am I missing something here?
