My Eris becomes lagtastic when i unlock it and i don't know what to set my profiles as to help this.
), have a look here, bigb:[B]Prio Min Max Governor Criteria[/B]
80 x 480 G Temp > 50.0 C
70 x 480 ondemand Screen Off
60 x 480 G Battery < 20%
50 y 604 G Battery < 40%
40 y 710 G Battery < 65%
30 y 768 G Battery < 100%
20 y 768 G Full/Charging
where x,y,G depend on the kernel:
[B]OS/Kernel x y G[/B]
2.1 ROMs 160 245 ondemand
2.2 CM6-Froyo 19 19 ondemand
[COLOR=grey]2.2 CFS & BFS 245 245 interactive[/COLOR][COLOR=red] (retracted, see note below **) [/COLOR]
"787/710" .. aggressive stuff.![]()
also make sure to ditch the setcpu widget, causes a lot of lag on unlock for some people.
whats everyones opinion on baked-in OCs (xtrrom, xtrsense) vs a setcpu profile? There shouldn't be any difference, right?
No set cpu for me here. Crazy fast ROM. 528mhz ftw.
Another thing, does anyone's phone run hot while charging? My phone get's up to 111 degrees while charging. I don't think that's normal.
111 degrees is inching up toward overheating, although not quite there.
not normal? its absolutely normal to get hot while charging, especially charging from the wall vs. usb. Even moderate heat during use or storage WILL decrease the life and capacity over time of a battery. by the time it affects you, it will be time for a new phone or at least a new battery anyway.bigb3456 said:Another thing, does anyone's phone run hot while charging? My phone get's up to 111 degrees while charging. I don't think that's normal.
111 degrees is not overheating, and not worrisome in the sense of likely damage to the device or battery, that's why I posted my response to the question as I did.
111 degrees actually is overheating. HTC's temperature specs say that operating temperature range is through 40C, which is 104F.
Help. Just installed SetCPU and setting up profiles, but in the main menu the max speed is 528 MHz. What gives?
That's the problem: in the main menu, the max I can scale it is 528 MHz. I can't slide it any higher than that. Does that make sense?
SetCPU is listed as one of the Superuser Permissions.
