EVO 3D has twice as much RAM and 4 times as much Memory as the EVO. EVO 3D has a 1.2Ghz DUAL-core processor, compared to the original EVO's 1Ghz SINGLE core. 3D will have Android 2.3 (gingerbread) and HTC Sense version 3.0, a larger battery. A much better GPU. A glasses free 3D qHD screen ...Just to name a few.
Additionally, the evo 3d does not have a kickstand and has the charging port on the left side - not the bottom.
the charging port on the left side of the phone is a complete FAIL, infact it may be the determining factor for me purchasing this phone
Without a kickstand, why does it matter that the port is on the side?
Assuming you will buy an after-market case with a kickstand, don't you think they will quickly catch on and allow the kickstand to flip in the opposite direction? The phone will rotate the screen appropriately.
because I cant talk on the phone with the charging port on the side, just like with any other phone, its a total Fail, i could care less about the kickstand
you obviously dont get it, so dont even worry about itIf you get distracted by seeing a cable out of the corner of your eye and can't speak because of it, switch to the other ear.
how is seeing something a distraction, IF IT IS IN THE WAY, IF MY PHONE IS CHARGING AND I HAVE TO PICK UP THE PHONE AND USE IT, THE CORD ON THE SIDE WILL BE IN THE WAY
hopefully you can understand now, and if you dont understand, don even worry about it
To put the processor into perspective, it is 2400mhz (two cores at 1200 each) vs. 1000mhz, so nearly 2.5 times faster, along with the gpu which is 4 times faster and double the RAM, as already mentioned. Android IceCream Sandwhich (2.4 supposedly) will take advantage of the dual-core processor phones like Homeycomb does with tablets.
