Memory usage preset: Moderate
Use Homescreen Cache: On
Homescreen Cache Type: Normal
Build Caches as needed: Off
Clear Caches on exit: Off
Prevent Force-close: On
Pretty much unusable. But that's because its loading all the widgets and still starting processes.Thanks. Is anyone's Eris unusable for the first 10-30 seconds right after you reboot your phone with LauncherPro?
Do you guys have the Keep in memory option checked under General Settings?
