What Battery widget is everyone using?
sean76
Android Expert
What's everyone using...
For some reason the Beautiful Widgets battery widget is not working for me? Just won't calibrate correctly, may be a 4.2.1 thing?
To me its nuts that its not something standard in Android that you can see the battery percentage in digital form running up top next to the time.
I use BW for mine and it works fine for me, agree it's pretty silly you can't see the % by default on the top bar.
I haven't received my Nexus4 yet, but when I had the S3 I used Go Launcher and used "Go Switch Widget". I had battery (which shows the percentage), flashlight, rotate, and vibrate on the widget. I could have put wifi and all the others, but they were already in the Touchwiz pulldown so I felt I didn't need it, but they have tons of options to put on it.
There's a non-Go Switch Widget available for download too (lots of ads though)
https://play.google.com/store/apps/details?id=com.gau.go.launcherex.gowidget.switchwidget
