What browse do u use?
ZeroShot
I'm trying out mobile opera. I like it but I can't play YouTube on it. It gives me some error.
Want to see what u guys r useing. Cause I want something fast but still can do everything. The stock browse just loads too slow.
Dolphin Hd is the way to go. Best one out there.
I have the metro pcs samsung admire, if you do as well. Then download Dolphin Hd, and remove the metro crappy one.
I download dolphin mini its good. Does everything I need so far. Im going to keep the stock browse for now. I heard bad things can happen sometimes after uninstalling it.
Well then just set Dolphin as default browser, andI just keep the stock browser sitting idle
Sent from my Samsung Admire. with Tapatalk
I use dolphin mini which is phenominal with video playback. I am able to fully run videos without any pauses. And only have 0-2 bars of "3g". Although i dont like how long it takes to load some web pages.
best browser i think ppl test and let my know if you like this browser ok maxthon from pandaapp change agent to android in the options google pandaapp maxthon browsers
I actually have a problem with the dolphin browser (seems to be the only problem really), whenever I'm searching videos on youtube from the browser the keyboard won't pop-up when I use the youtube search bar to search for video's, instead I have to use the main search bar (dolphin browser search bar). Why does this happen?
I use opera and chrome since they can switch their user agents from mobile to desktop and they're pretty speedy
i used to be a fan of Opera for pc but updates hobbled it...but,Opera Mini has been solid and smooth ...tried mozilla because i swear by it now for PC but, it takes up a huge amount of space....and since space hogs are the Admire's worst enemy i did'nt even consider it..
sorry...i get to typing and have to remember to stop :rolleyes:
