The one I posted about a few posts above.
Thanks, I ordered the Nillkin last week so hopefully it'll be here any day now.
Case looks great but it does not work with the docking stationI too have the otter box and love it it also comes with a built in screen protecter
Great review. Can you describe the TPU material? Is it the same as any other? It almost looks shiny on the top end where it surrounds the screen bezel but a different shade elsewhere. Is it just the lighting? I need a true TPU case so it doesn't slide around on my car's console.
Thanks much for your help!
Mike
UPDATE: Just received the Nillkin hard case. It's a snap-to-back case.
Pros:
very thin, but not paper-thin;
light texturizing on back;
non-gloss;
circular cutout to frame the "M" on the back.
Cons:
the cutouts are cut very close to the buttons, so you can almost forget pressing with the pads of your fingers. You almost have to use your nail. For some, that may be a good thing to prevent inadvertent presses.
I have this case and I agree with the review. I love mine!UPDATE: Just received the Nillkin hard case. It's a snap-to-back case.
Pros:
non-gloss;
Cons:
Have you seen the Cruzer lite androidified cases. Pretty sweet
http://www.amazon.com/gp/aw/d/B0060QVLMY/ref=mp_s_a_6?qid=1331305837&sr=8-6
The tpu cruzerlite skins I ordered arrived today. They look great and fit perfectly. Will post pics shortly.
FussBoss;[URL="tel:4062295" said:4062295[/URL]]I have the white one and love it! My wife got one for her Rezound also. Very good case, and I like the Android guys on it.
I use this also. The kickstand is very convenient and even if i don't use the holster, the shell doesn't add much bulk so carrying in my pocket is no problem. The texture of the case makes the phone easier to hold than without the shell. The finish and backing of the RAZR are wonderful, but slick and I get the dropsies sometimes.I picked up the Shell/Holster from Verizon, thought it would come in handy if I needed total protection of the screen if I'm out on a bike ride or hiking, etc... It was a little pricey @ $30, but I get 25% discount still pricey.
Very nice construction, doesn't add much bulk with just the cover, I like how the area for the power and volume are left blank and the top and bottom are exposed. It is a very secure fit, the kickstand feature is sweet for watching videos or desk clock. It had sort of a slippery feel to it when I first opened it, kind of like a silicone residue. I wiped it down and rubbed it aggressively against a towel to remove the residue...has a secure grip in hand.
It also fits in the car dock, so I don't have to take the case off when I jump in my truck! When you remove the plastic insert of the dock to use a case you will notice the phone is a little loose in the dock. I put a small piece of adhesive felt at the base of the dock to take up the space....It's black in color so doesn't look too ghetto and does the trick I'm only showing pictures of the case, not the shell w/belt clip.....left that out in my truck
Otterbox commuter all the way.
