My Droid X arrives today, How do I handle the battery at first. Do i use it, let it run down, then charge it. Or do I charge it right away when I get it and then use it? Thanks!!
I did three cycles of charging completely, then letting it run completely down (or almost completely down). I've had very good battery life so far, and it seems to be improving the longer I have the phone.
Also, you may want to go into battery manager and set the phone for either smart or battery saver mode--helps with battery life.
