In Linux it means that you basically gain control of all the functions of the OS, and have privaliges to change anything you want.
If you're not rooted then you are basically using the OS as a guest, meaning that you'll have to enter a password to gain access to certain functions of the OS, this is what makes Linux so secure. I assume Android is the same as it's built off Linux.
