Help What Driver to Use
mvtechnet
I have downloaded the Samsung Driver Pack but the computer still does not see my Precedent. I saw someone here say use the prevail driver but I dont see that anywhere. At least not by name. I have tried forcing friver update on the unknown device but no matter what driver I try to use for the phone they all fail to install.
Thanks for any info
These phones are very similar to the prevail. Make sure you read alot before doing anything. There isnt as much support as there is for the prevail.
Can you post a link to the rom then please? I've rooted and done everything just lie I dis my prevail and everything works but cm7 wont run because of the build prop. I don't know how to do it. Thank you. Everything else seems to work good though. I've got cwm and flashed to an ej06 image.
Go to androidarea51.com
Login or signup
Go to precedent rom releases under forums
Go to cm7.1
Find my post [how to install cm7.1 with root......] follow all instructions to the t.
Then please donate a dollar or two to aa51@androidarea51.com pretty please, site is struggling
