What exactly do the power settings do?
rcyphermd
Android Expert
I have been very pleased overall with my battery life on High performance. When I tried normal mode, my gmail no longer pushes as it comes in. The economy mode you can pick and choose. What does normal mode do?
This is a great question, might be worth looking in the manual linked in the sticky, am thinking it would explain it there
This is all the manual says:
Optimizing battery life
You can set HTC Rezound with Beats Audio to automatically switch to
power saver mode when the battery level reaches a certain level.
1. From the Home screen, press MENU , and then tap Settings.
2. Tap Power.
3. Tap Power mode > Economy.
4. Tap Turn power saver on at, and then select when to switch to
power saver mode.
No details on what "normal" setting does.
Any one know?
Sheesh, you guys are over analyzing this.....the power settings set your power..... You're welcome!
