Help What exactly is Active Sync?
Soooooo...can it be used with AOL?
I am still slightly confused. Should I be using the regular email for my device or use Activesync?
I'm not sure why you wouldn't be able to. Active Sync is typically used with Microsoft devices... Hope this helps...
Thank You. I appreciate the answer.
Now, if I do set up the ActiveSync for AOL, will it go to the regular email or do I need to use the ActiveSync mail widget??
