I've never used Harmonia, but I think it's a lot like MeanROM ICS on the Evo 3D and intended to be very close to stock with fixes for things that were broken by HTC and some tweaks for performance and battery life. Once that type of ROM is fully tested, there's really not much else to change and it's up to the user to choose additional mods, customizations and tweaks.Did leslie ann (sorry spelling) stop making harmonia?
The audio mods are more release dependent than the camera mod and more likely to break something, so you should probably stay with what you have if you like it. According to the Harmonia OP beats and dolby are included already as well as an enhanced camera so the coolexe mods might be baked in:I'm running Harmonia with Anthrax 3.7.0 and it's nice.
@ramjet, I also added the cameramod you linked to in another post and have seen better quality photos.
Do you think the soundmod will help? Sound is already excellent though.
The one mod that might improve sound, or at least make it louder, is the xloud piece of xxxpachaxxx's Sony mods. If you want to try it I would definitely recommend doing a nandroid backup before flashing it and testing everything audio related very thoroughly afterwards. There is a link to the version you need in this post if you want to try that on Harmonia.Beats, Dolby, SRS, EQ
Better camera, supports many modes (panorama and hdr)
