jojo99
Member
I am new to smartphones.
Three weeks ago I brought the HTC EVO V. Generally it works well except for one major problem. I get poor mobile phone service in my home (but wi-fi is OK, so that helps overcome the problem).
What I see is the signal strength bars keep going up and down, as if the cell tower is turning. Mostly the bars are at 0-2 but again, the strength floats around, which everyone I talk to tells me is unusual.
So I have spent some hours arguing with VM about this problem. They claim they have done maintenance work on the towers and so on. So then they offered to send me a new phone. However, the phone turned out to be an older (based on the serial number sequence) Sprint branded phone.
In trying to get the "new" phone setup, I swapped the SD card from the old phone into the new phone.
But after doing this, I lost most of my apps and settings, which was unacceptable.
I had backed the apps up using a pp called super backup, but when reinstalled in the new phone, it could not locate any of the previously backed up settings it had made (although I could clearly see those files on the SD card).
So questions:
1. WHY would the signal bars fluctuate form moment to moment when the phone is stilling perfectly still in one place?
2. WHY do I lose all my apps, contacts, settings, etc. that is on the SD card when I move the physical card from one phone to another? Is this some Android/Linux design problem?
Thanks in advance.
So questions:
Thanks in advance.
