Root What is a bootloader?
thecorey
I bought my little brother an original motorola droid, he just called me to tell me all it say is BOOTLOADER, What is the bootloader for????
A screen that most people end up at when the battery is to low or bad. Try a battery pull and make sure it is charged.
Then try to boot or get into recovery.
It is a way for getting one's boots put on to your feet without bending down
:D
As said there above, it is a little like the bios screen that flashes up on a PC when you are starting it up. If it sits at the bios and doesn't go into Windows something is amiss. With a Droid if it sits at the bootloader....same deal.
I need a bootloader LOL.....my head hurts when I bend over. This cold is kicking my arse....:D
:D
