what is debug intent sender, screen resolution settings, etc?????
am i the only one to get these things?
  • yes
    Votes: 0 0.0%
  • no
    Votes: 0 0.0%
  • Total voters
    0
  • Poll closed .
hi,
today i downloaded gesture search from the market. After installing it I busy exploring it (by just doodling anything) and some search results came out like display settings(which had an option to change font size though didnt work out) display resolution settings,debug intent settings, "select activity" settings, 4G settings, etc. So i wanted to know what is exactly the use of these setting option? thnx in advance.
hi,
Basically they are activities, settings which are in your device, they can also act as shortcuts to specific paths on your Wildfire with one tap, like for instance your "screen resolution" here is a link to a thread which explains what it does
Note that every single app you have even system ones, will show up there
Not all the activity shortcuts will work, the ones most likely to work are the 'system' ones
