Help what is ram clean up ??
tulikasri
first of all please can any body make me understand what .. if my ram is full.....?? what is ram actually ???
i have a ram size of 398 .. out of which 250 space is already full i have moved my apps such as games angry birds , temple and feird run to my sd ... but still nothing happened my ram is still as it is and ya when i press clean up not whole thing gets clean up very little gets clean... . .why so ?? i have around four apps till now.. . .please help me thank you :(
Ram stands for random access memory.... It runs all your application.... Apps you moved were stored in internal memory so that won't effect.... Your phone supports multi tasking.... That means your ram is full because you have many apps running in background.... You need to clear ram... And also a good task manager with help a lot..... For more information google search...:cool::cool:
Moving apps to your sd will not help with ram, since ram is only used when you open an app.
Also, moving apps to your sdcard often causes problems so be careful doing that. :D
Unused ram is wasted ram. Android (esp GB and ICS) handles memory quite fine on it's own without your intervention. By keeping an app memory resident, you can reload it quicker.
IMO you are worrying about nothing. :D
250 out of 398 is not a problem. Ram is used here to keep apps in memory for faster opening, so having it well used is good. Also, android manages ram effectively so if it does get used up, some apps that are not being used will be killed to free up some ram.
