Root what is taking so long?
Can someone please explain to me how the esteem can perform so slowly when doing anything data related when I'm hooked up to 10mbps broadband internets via wifi? tthought it was my connection until I set all my android devices next to each other for a connectivity and speed test. the other devices worked flawlessly as the should but the esteem was the only device to take more than 30 seconds to even begin rendering the pages. i've tried every ROM and they all do this after about 2 days of a new flash...why is it that the stock ROM can maintain consistent data speeds while the custom roms stutter?....how can I correct this?
Haven't seen that issue at all with any of the custom roms. Try clearing out your cache/history in the browser you are using.
Maybe that is causing the problem.
if i get lag which happens every once in a while i normally restart. dont know y it helps but im assuming just like a pc needs to be restarted every once in a while.
I've had that problem a few times, & I did just that...cleared all my cache & history.
Another suggestion would be to move all the downloaded apps to the sd card. Keep as much stuff off the cpu as possible.
When I do all that, my baby runs super fast :D
