I don't have evidence, but my perception (from personal experience) that LeeDroid is best for battery life. Although technically, if you use any Sense based ROM with his kernel, it should yield pretty similar results.
Cheers for the thoughts, i re flashed CM7.1 and took a load of apps off and the battery life is pretty good, getting 16 or 17 hours out of it now so quite happy. Just wish Orange had a better 3g network around Bolton and Manchester!!!![]()
You know Orange and T Mobile share the same signal now?
My Orange signal at home is pretty poor so I've to manually select Orange T-Mobile. Previously it would only pick up a 2G signal, but I've noticed a 3G and occasional H every now and then.
You might want to give the Orange T-Mobile signal a whirl.
Once i installed cm7 i then updated to the latest Lordmod kernal
and el pres sent me links to the post about undervolting
made my battery last even longer
