D
Deleted User
Guest
What is the largest battery that will fit with an OEM battery cover?
The biggest Ive seen is the 1750 mAh battery by Seidio: seidioonline.com
It only provides a bump of 10% to 15%, but if you use something like Juice Defender with it you should get significantly more battery life.
I got a 3500 that came with a cover on ebay. Have been using it for 6 months or so. It makes the phone seem bigger, but it still fits into my pockets just the same, and it also seems to fit nicely into my hand.
It is almost impossible for me to run it down. I was trying a battery calibration app out and it said to charge to 100%, then unplug and let it drain to zero for best results. I worked on it all day, playing pandora and watching videos. By the end of the night, I went to a video site and found a 30 minute flash video, and played the same video over and over until my battery finally got to zero. I think I hit replay at least 5 times.
