Is there a separate app for undervolting or is it usually included in some of the overclocking apps?
quickclock did nothing but cause my phone to reboot after installing
I've actually had good luck testing my own settings
the reboot is intentional. It keeps dropping the vsels until it reboots. Then you open it back up and it runs the other calibrations.
This ^
Now open quickclock back up.. go to overclock and hit calculate.. whatch the Vsels change
Then hit Setcpu
When it ask me to Select Calibrations to Run, do I just check Voltage, or all 3 (Voltage, Max Speed, and Profiles)?This ^
Then hit Setcpu
Where are these profiles. I haven't seen them on QuickClock yet, are they on the Overclock by JRummy?I'd recommend selecting all 3. It doesn't hurt then if you want to use the max sported or profiles then that if your choice. I find them to be pretty handy and help get the most out of the app you already bought.
Thanks dmiller, I forget about the menu button too often. Are you the dmiller from the Nascar site?After you have ran all of the calibrations, go into the Overclock menu of the app. Hit the menu button and tap Load Profile. it will then give you options of profiles to apply. just tap whichever profile you're interested in.
Try this thread cyber, about 2/3 down the page, the Overclock sections.Thanks for this thread. Been looking for some info on how to under volt and/or over clock my X. This thread shines some light on the topic. I have Droid Overclock and have no clue what to do or how to use it to do the above. I also have SetCPU, which I have one profile setup to drop the CPU speed to 300 with screen off and that is about all I have figured out.![]()
http://androidforums.com/droid-x-al...ide-root-unroot-backup-rom-sbf-overclock.html
