What launcher are you guys using?
i've enjoyed the nova launcher on my note 2 so far but was wondering if there were other ones out there that you all liked more. not a fan of the go launcher btw. i've heard good things about holo and lightning, but haven't actually tried them out yet
thanks
I've been walking around with nova installed but unused for months.
I've never found a real need for it that would make up for the time it would take to set it up.
So I still use TW.
So I still use TW.
Nova has an import option. You could import your setup from Touchwiz & tweak it little by little. It really doesn't take long if you're not doing any heavy customizing.
I tried using both Launcher 7 and Nova recently but there were a few things that put me off them:
- Launcher 7 seemed to drain the battery quicker than TW
- The S Planner widget wouldn't work with either of them
- I couldn't find a way to create folders within the app drawer in either
So I've gone back to using Touchwiz, which does everything I need it to really.
I couldn't live without my gestures on Nova. Plus it's a lot easier to make folders.
On Nova you can set your gestures so that a swipe up on an icon will perform an action, like open another app or instantly go to that person's text message string.
I like it. Although if I never used it I wouldn't know what I was missing.
