stray_pube
Just curious what things are completely unneccessary so I can clean up the app drawer a little. Things like Blockbuster? Vlingo? Asking here because I don't want to delete something I shouldn't.
You will need to root your phone to delete those preinstalled bloatware apps.
You don't need to be rooted to un-install any of those apps. Go to Settings --> Applications --> Manage Apps. From there you can select an app and it will give you the option of removing it.
You can do without Blockbuster, ATT Navigator, Family Map and Vlingo.
None of the apps listed there are vital to the phone. Just make sure you stay on the first tab which says 'Downloaded'.
Vlingo isn't in the "Downloaded" tab. Can I still uninstall it?You don't need to be rooted to un-install any of those apps. Go to Settings --> Applications --> Manage Apps. From there you can select an app and it will give you the option of removing it.
I wish I could uninstall Vlingo, but my Atrix won't let me. I attached a screenshot as proof.
No, that's 'voice command'. Vlingo allows you to video chat and 'make calls' using data.I think you need vlingo to use voice dialing
I thought Vlingo was nothing more than a speech recognition software used for voice commands and speech-to-text.
