New Rising
I've tried axiombeam, liquidsmooth, and cm9 but now I'm back to the stock 232 leak. Of the roms I probably liked axiombeam the best. What rom is everyone using and which do u think is the best?
Now, stock .238 with GNow for ICS.
I am stock .238 with GNow for ICS.
From what I have been reading, there are really no ROMs compatible with .238. Everyone is developing for .232.
I don't really need a ROM b/c .238 is a vast improvement, I just miss customization and debloating.
I am considering installing the deodexed .238, just so I can customize a little more.
Yeah, the devs haven't jumped up to 238 cuz there's no return. If they find a way to get back to gb, there will be roms out then.
OCed to 2.7Ghz
Haha. I fixed it. Im fairly sure the Bionic would commit suicide at that speed.:vroam:
I would make the jump, but I tried out a ICS Blur ROM, and I'm just going to say that I couldn't stand the UI changes. The normal AOSP apps look so much better and cleaner, while the Text app in Blur is horrible.
There won't be a way to go back to GB without an unlocked bootloader to flash old radios and the like.
You can still be on .235 or .238 and flash something like the CM9/AOKP builds. They work correctly, and even some .232 ROMs will work, same as how we had .893 ROMs working when people were on .902 leaks.
Yeah and you should be able to upgrade to official if it ever gets released lol
ICS-LEAK .232 w/ AOKP 7/25 on Safestrap.
How long ago did you download 7/25, Tehsusenoh?
Did you have to do anything special to get this running? I have AOKP 7/13 running on .232, and it runs great. I downloaded 7/25 a couple days ago, cleared data, system, cache, Dalvik, install zip, etc... and it just blackscreens after the Safestrap splash.
I can flash back to 7/13 all I want, but 7/25 is broken on my Bionic. Weird.
The Droidhive site has been up & down a lot lately, so maybe the files became corrupt or incomplete in the past couple weeks?
If so, then maybe folks reporting success downloaded it before the site instability occurred. AOKP has always installed great on my unit, so I'm at a loss to explain it. 7/13 runs fine, so I'm sticking with that for now.
in preparation for an official ICS build, with a kexec and CM10 soon after.
I didn't know anything about a kexec for Bionic. Who's working on that, the CM team... others?
That's really cool!
