Root What roms do you guys use? CDMA ONLY!
liamf1
So I'm new to all of this rooting and flashing rom stuff. So Im just wondering. Do you guys have interesting CDMA/UsCellular Roms you can share with me? I'd greatly appreciate it if you would post links and/or images. Thank you! :)
But I have CDMA with boring roms. So if you'd be glad to share cdma roms, that'd be great.
Personally I couldn't say anything, I haven't looked into any.
What kind of ROM you looking for? Sense? Aosp?
I'm looking for sense roms. But everytime I try to install one with a cdma converter file it comes with... I always get an error in the recovery.
The error is this... BTW I downloaded this rom 2 different times and it happens with both BlissMod007, and RunnyMedeMod007...
Heres the error...
finding update package....
opening update package...
Installing update...
Install RunnymedeMod007 + APPS2SD
for the HTC Desire
-----------Progress-------------
(((ERROR STARTS HERE))
assert failed: getprop("ro.product.device") =="
bravo" || gerprop("ro.build.product") == "
bravo
E:error in /sdcard/RunnymedeMod007_v21_c-CM7-Stock.sip
(status 7)
Installation aborted.
It says to do this on the website if I use cdma...
NOTE: Manually delete this entry from the updater-script: assert (getprop ("ro.product.device") == "bravo" | | getprop ("ro.build.product") == "bravo");
How do I do this?
I even installed the CDMA PATCH that came with IT. Gonna try Runnymede and let you know how that goes.
It's a requirement in the thread is it not?!
Most of these newer sense roms are too big for the desire and require ext partitioning.
Whatever is required, is mentioned in the thread. Read the threads and you should have a good idea what you "need"
Swap size 0. Sounds like you're using recovery /manager to.partition. bit of a no no.
You can press thanks under any post ;)
