trying to learn as much as i can by reading but still not understanding alot. i am using rom toolbox lite and was wondering what is the best cpu settings. what should my governor, i/o scheduler, and min. and max. mhz be set at?
You should post in the all things root section.... it all depends on how much you use your phone during the day.... sio ondemande is a good setting and depending on what kernel you are using I have mine at 1804 mHz but a more conservative setting its usually around 1401.... Hope it helps!
