What size SIM Card in SGH-i717 Note?
Ashton2
I need to order a SIM card for a pre-owned Note, not Note II.
Does it use a mini or regular size SIM card? The search results i'm finding on this are inconclusive.
Thanks
Mini (not micro).
images
I haven't seen any adapters, but wouldn't be surprised if they do exist.
Some of the confusion might be because the Note II uses a micro sim.
In the first photo I posted (taken from the web), from left to right you have mini, nano, and micro. I've re-attached it to this post, annotated. I think you should be fine with the Straight Talk offer. It looks like a mini.
Mini is standard/regular etc etc. Sometimes it will come in credit-card size with the ability to push out the mini sim.
