What steps to take after rooting?
rgr555
I successfully rooted the Galaxy S2 using step 2a from this page: [GUIDE] How to Flash Custom Binaries Without Ever Incrementing the Flash Counter!! - xda-developers
Now I'm confused about the details for the next steps 3a and 4 (from the link).
I purchased Mobile Odin PRO on the Market and installed it.
Can I go straight into installing a ROM .zip file? I want to try this one, [ROM]<=TASK650's ICS'd OUT! V9=>[JKayMOD,BRAVIA ENGINE,ICS ANIMS,BLN,ECT...](12-20) - xda-developers
Do I need to install a kernel first? If so, any suggestions?
Thanks
you need to install a kernel first that has cwm recovery. i used entropy's daily kernel or something like that. you download the .zip, extract it and you will select the zImage in Mobile Odin, which will install the new kernel. next you download the ROM you want to install and put it on your phone. then you boot into recovery by turning the phone off, then turning it on while holding both volume buttons down. that boots into recovery, select 'install .zip.' find the zip of the ROM you want to install and install it
