So when on WiFi what does H+ with a check mark below mean???
Pretty sure the H+ with the check mark while on wifi means your mobile data is turned off because you are on wifi.
I have the mobile data toggle widgit on my phone. When I turn mobile data off, I get the same result, the checkmark under the H+.
PER AT@T, thats exactally what that means, plus i think there is a setting for it to.
Slightly off topic
Wow !
I'm really enjoying my Inspire, this phone is so good, I almost don't know how to act![]()
I honestly got 16 hours of battery life today. Took it off the charger at 9 am and was connected for about 6-7 hours on wifi but still on the web most of the day, plus about 50 texts, and 10 calls.
I freaking love this phone. Its build quality, battery life, UI, design, and just about every other aspect. Its absolutely amazing. Plus I sold my captivate today for 200 which certainly helps![]()
j/k bot sorry
it means you are touching your phone too much Andrea!!
It tells you in your booklet. The H means your connected to 4g. H with the arrows up/down means your transferring data. When your connected to Wifi you'll see a H+, that means 4g is ready and available but Wifi is recomended. Sometimes if the signal gets low enough you'll see a E.
It doesn't tell you in your booklet what H+ with a check mark underneath means
I read that after a few full drains and charges the battery will work better... I'm hoping that is true because I haven't seen battery life like what you're describing yet. Only had it for a couple days now though.
It won't even last half a day...it dies so fast. I disabled the Wi-Fi so it can't be that... I mean I like the phone, but the battery life I HATE!
