Help what the hell! water damage!
tonyv69
Member
i have the seido active case, and I took it off yesterday to check for dust/dirt under it.
when I opened the back cover both the little water check sticker on my phone and battery had red lines criss crossed on them. when I first got the phone I thought they were plain white. I know I haven't gotten the phone wet....
Hey mods, can we sticky a post that says " think your phone got wet? Check here first."
thanks for the quick response... I was tripping out.
guess I should have paid better attention the red insides must have blinded me
Doesn't actually matter I don't think — doesn't the insurance plan for these phones only come in the $7 variety which covers water damage? Correct me if I'm mistaken.
how do you fix it if it is red? ..happend to mine and i know it hasnt been in water... thanks
Don't think there is much you can do.
There is another water indicator inside the device also when you take the back off. (not the battery cover, the back that can be removed once screws are taken out)
