Root what themes for bugless beast 2.1 ??
loco
im running bugless beast 2.1 and would like to try some of the themes. i have the premium version of clockwork mod recovery and see many themes listed. but they all seem to be listed for the cyanogenmod and i dont know which ones will work with bb.
can folks running bb tell us what themes you have ? maybe what themes you like ?
Take it outside, another bunch of crabbly posters telling others to use the search button, yawn, gets old. If you don't want to help him, don't.
I'd say the one of the most popular is called Smoked Glass. Check out NexBeast by Fabulous.
Do you mean BB froyo 0.2.1 or 2.1, like pre 2.2?
And fine, since everyone thinks I am an a$$ here:
http://androidforums.com/all-things-root-droid/48964-metamorph-themes.html
I personally like Luna theme (available via update.zip)
and DropTheme, which works on my 2.2, but the 2.1 versions are out there too.
A beta out for 2.1 DropTheme with some supposed nice improvements.
This is also update.zip
DropTheme [MM] - Droid Forum - Verizon Droid & the Motorola Droid Forum
Happy now?
:P
From the Forum Rules & Guidelines:
while the search feature on forums is great, and hopefully will be utilized - if someone comes here and asks a question, either answer it or don't. If you're going to suggest the search feature, be polite about it. Nothing irks me more than when I go to a forum, (and use the search!), then ask a question because I want some one on one with my problem, and get a simple "Use the search." reply. Suggesting it is encouraged, but don't withhold the answer because they don't.
I trust that this clears up any confusion.
