Can we see which apps you use? Thanks!Well brother, I suggest you start by downloading so necessary apps, I give you my list and you can try then choose the ones you like and we'll use.
http://www.appbrain.com/my_apps
I suggest...
Advance task killer - to kill apps running in the background or not being use
Astro file manager - To explore the root of your memory card
Beautiful Widgets - Weather and Clock Widgets that's awesome
Rindroid - To make your own ringtones from your music on the phone
Places and Directories by Google - To find anything you want
Also go to the market and check out the apps that have the best rating and check the comments of other users of this apps.
Also this phone comes with 50+ Widgets from HTC and Googles, so have fun.
I hope this helps.
Why is it a bad idea to use Task Killer? What can you do wrong? I went to a Verizon store yesterday and the tech installed it on my phone.
Sorry... I don't speak with Reds fans.You darn cardinals fans... lol jk, click on the link he posted, appbrain apps are the shit!! here though the app market is really coming up.
Go First Place REDS!!!!!![]()
Thanks for the help...I'll check out your apps.
