Biggest Fro
Should I get a replacement Evo?
I have a version 2.
NO light leakage.
NO random reboots/crashes
I DO have the "Grounding" issue when sitting on a couch. (Not a huge prob. bc my phone is in my hand 95% of the time I am using it)
Battery life is excellent, 14 hours+
and now the kicker..
Glass separation.
It is not separated, but I can notice the bezel is deeper at the top of the phone than near the bottom. At the bottom the glass is almost flush.
My only worry is that over the next year (the time until my Prem. contract is up) the separation will get worse, and then I will be out of the 30 day window.
Do you think HTC will "Recall" the defective phones? They have acknowledged that there is a problem. But they only said they worked on a fix at the factory. Nothing about a recall.
What are your thoughts?
I have a version 2.
NO light leakage.
Glass separation.
