Once rooted you need to download titanium backup. That will allow you to remove unwanted appsHi,
I own a HTC Wildfire S and I like to know how to move/delete Facebook and maps.
I've rooted the damn thing, and am still looking to make it work my way.
Thanks for the tip.Once rooted you need to download titanium backup. That will allow you to remove unwanted apps
I'm finding link2sd much simpler to use for removing apps.
Can anyone explain the difference between linking to sd and moving to sd, and which is the better option?
Linking to SD card definitely. that is what you should do. It will save you loads and loads of space. I have linked almost all of my apps. I easily have about 30 odd and still have between 30-40mb of space (Running CM 7.2)
using link actually give you much much more spacebut why link rather than move to sd?
hmmm...I'm not sure if it will allow you....can superuser be linked to sd?
Don't know what Qype is. But I don't have it so I guess you canCan Qype go? And Hub sync?
