Accessories What type of memory card do I get???
micool11
Hi I was wondering if someone can help me out. I want to buy a new Memory card for my Desire. I want either 16GB or 32GB but I just don't understand the class of the cards. I know it has something to do with read/write speeds but will this effect the phones performance if I get a class 2 card as opposed to a class 6.
The class number is the minimum Guaranteed read/write speed. Eg class 2 is 2MB/s and class 6 is at least 6 MB/s
Try to avoid ebay at all costs
Hope it helps!
I would probably go for a class 4 or class 6 there are (as far as i know) 4 classes 2, 4, 6 and 10. You will need at least 4MB/sec write speed for 720p video recording when you get froyo. I dont think that class 10 is recognised by the desire but i could be wrong (and they are very expensive anyway)
I personally have a class 2 16gb pny card but i got it because lots of reviews stated that they were getting much faster speeds (5-6MB/sec) than the class rating. This is because the class rating is the guarenteed minimum transfer rate with high quality cards like sandisc etc you will probably get much faster than rated transfer speeds.
Btw mine was
When you transfer the file there should be a little downward pointing arrow to click on to expand the details and it tells you there what speed you'll get.
