TriumphLance
I'm at 1.4 ghz with Cm7 and this thing flies compared to stock is this safe or any risk in running it here? It froze at 1.8ghz..and do you think its gonna hurt the battery life?
If it's not locked, it should be relatively "safe". I'd make sure it doesn't get too hot though.
Obviously the phone is designed to run at a certain speed and running it at higher speeds will shorten the life of the handset.
Just leave it at that if you're happy with it then. It's best to go for a balance of speed Vs stability with overclocking and if your phone is fast enough and stable enough at 1.2, it's cool to leave it where it is.
I run mine at 2Ghz most the time and never have any problems besides getting a little toasty. Nothing too alarming though. Some kernels are more stable that others it seems though.
what kernal are you using for a stable 2 ghz? Also does anyone know which governor is the best I don't know the difference in them.
its stable at 2 ghz for me, but its bad to Oc that high. and i think the "NOOP" gov is the bestwhat kernal are you using for a stable 2 ghz? Also does anyone know which governor is the best I don't know the difference in them.
I think this should shed some light. This means that it should run absolutely stably with no problems or issues upto 1.4GHZ after that its your call.CPU Single-core Scorpion CPU up to 1.4GHz
Well I would say up to 1.4 GHZ is pretty much as safe as your going to get. If you take a look at the official qualcomm s2 snapdragon spec sheet from their website (the link is just to s2 spec sheet which is pdf.) you'll notice that it says I think this should shed some light. This means that it should run absolutely stably with no problems or issues upto 1.4GHZ after that its your call.
EDIT: Oh and by the way if you don't know we have a qualcomm s2 msm8655 snapdragon SoC. Just so you know![]()
I would say you are mostly correct, but if the phone was completely stable/safe at 1.4 they would market it at that. There is a reason it is sold at 1ghz.
