billy whizz
Member
hi - got a zte blade/san fransisco...anyway is battery info section it shows that "android system" using 98% of the battery.....is that right ?....im not using bluetooth, screen set to low level, no app killer installed...ta
My guess would be that 98% of your phone's current level of activity (whatever that may be) is accounted for by system activities because you haven't installed much of anything else yet that would need to use CPU cycles.hi - got a zte blade/san fransisco...anyway is battery info section it shows that "android system" using 98% of the battery.....is that right ?....im not using bluetooth, screen set to low level, no app killer installed...ta
My phone seems to have used most of the battery charge overnight. I did have it set to use the GPS as the wallpaper, so I suppose it might be that. Now changed to a static wallpaper instead. Is there anything else which is likely to be running the battery down when the phone is off please? I don't mean totally switched off of course, just not in use.
