TJayDroid
Was just about reset my Motion in order to simply start with a clean slate again (unrooted, stock). A general clearing out of sorts instead of going through all the crap apps I've installed in the last year.
Backed up all the stuff I needed and was about to reset when I noticed that there are two methods of resetting to factory. One involves the following:
How To Hard Reset A LG Motion 4G(MS770)
1. Power off phone.
2. Hold power and Volume down button( Until the phone virbrates).
3. Keep tapping home and back( at the same time).
4. Your either going to see a green robot or a menu screen.
The other is simply using the menu in the Motion's System Settings to access the "Backup & reset" option and then pressing the "Factory Data Reset" item.
Which one is best? Do they both accomplish exactly the same thing? Additionally, will utilizing either of these options result in needing to call MetroPCS to re-connect the phone? I've asked a similar question some months ago and people told me "no", that wouldn't be the case. Just in case, though... I'm asking.
1. Power off phone.
