Root Whats the difference...
Between 5.0.2.7. and 5.0.2.8....which one has more stable roms ?
Thanks :itsme:
They both have their fair share of stable roms. Only big difference is that 5.0.2.7 is mainly for roms/Admires that do not work well with over clocking. I, personally, like using 5.0.2.8, but thats just me. :)
As SacredBloodlin said it varies ....depending on what your into, if you a fan of overclocking and initid tweaks,etc (5.0.2.8 roms) are for you. But if your into non overclock and stability then (5.0.2.7 roms) is the right one for you...
The difference between (5.0.2.7 & 5.0.2.8) is that they run on different file systems.
5.0.2.7 runs on Samsungs RFS File System
While 5.0.2.7 runs on a EXT 4 File System..... personally 5.0.2.7 has the most stable roms to me, more battery life and so on....check out both versions for your self to get a feel of what there like, because I could tell you that its OK but it might be not.;)
