what's your car radio adapter for gs2?
Since I have an old Honda with a tape player I use either my Sony MH-100 BT adapter to a tape adapter or I plug the phone directly into the tape adapter. Depends on if I want to remove the phone from my phone.
I got this Belkin FM transmitter for my birthday and it is absolutely ace! It is always 100% clear as it uses ClearScan to find the best station and even allows you to charge your SGS2/iPod/iPhone as well via USB. Highly recommended
My cd player had an aux in, so I just run a stero mini jack cable from my head phone out of my phone into to the aux in on my radio face.
I find it eats less battery than the wireless options, and the sound quality is really good.
EDIT: this is also a really cheap option.
Yeah, I carry that cable on trips in case the rental car has that jack.
I use the official vehicle dock and connect to Aux-In. Works OK as long as you turn Phone Media volume right up, otherwise interference can be noticed.
