What's yours setcpu settings lg optimus v
rich33389
What's your settings for your setcpu on your optimus. Mine is 245/806 on interactive...not sure what I should set it on for profiles though.
Copied mine from someone else...
Main: 768/245 ondemand
Screen off: 245/245 ondemand Priority 100
Charging: 600/245 ondemand Priority 95
Temp > 40.4 C: 480/245 ondemand Priority: 90
Battery > 15% 480/245 ondemand Priority: 80
Advanced:
Sampling Rate: 50000
Up Threshold: 40
Ignore: 0
Powersave: 0
I've rooted and want add one of the Xionia Kernels, but there are now 10 and I can't figure out which is the correct one to use.
Any help from anyone who has installed one of these would be great.
Main: 729/320 OnDemand
Screen Off: 480/320 OnDemand Priority 50
Charging: 729/480 OnDemand Priority 50
Advanced (Default Settings):
Up Threshold: 90
Ignore: 0
Powersave: 0
I'm not that concerned with battery life, I bought a spare battery and a charger for it :)
