Root When 2.2 comes for Captivate ...
Thanks, it's just one click, right?
Uninstall the lagfix manually. If that doesn't work, flash to the stock ROM using Odin.
Either way, it's a relatively simple process, the worst part of which is hand-picking which of your individual apps to reinstall from Titanium after the fact (that's if you don't batch-reinstall, which I'm guessing you wouldn't want to do if you like not having AT&T bloatware on the device).
-Ryan
